simon_2
How to remove summary statistics using JSL
Hello users,
How do I remove graph summary statistics using JSL?
This is the ouput.
Here is the desired output:
I want to do this using JSL. Here is my simple JSL script to generate the graph from Big Class.JMP data:
dt = Open("C:\users\...........\Big Class.JMP");
dt1 = Logistic( Y( :sex ), X( :height ) );
Thanks.
Re: How to remove summary statistics using JSL
Here is a very simple way to do it
dt = Open( "$SAMPLE_DATA\Big Class.JMP" );
Report( dt1 )["Iterations"] << delete;
Report( dt1 )["Whole Model Test"] << delete;
Report( dt1 )["Fit Details"] << delete;
Report( dt1 )["Parameter Estimates"] << delete;
simon_2
Nice and simple. Thanks a lot txnelson.
I had to remove "Report( dt1 )["Fit Details"] << delete;" to make it completely remove all the remaining summary statistics.
jimloughlin
I left "Report( dt1 )["Fit Details"] << delete;" in and it deleted all the summary stats. When I commented it out, it left the fit details in.
Jim Loughlin
Loughlin Consulting
