mmarchandTSI
Level V
How to remove graph image
In some cases, it's helpful to plot data over an image, or, more specifically, plot XY locations over an image and enable a graphlet of the pertinent data.  We can quickly associate the gathered data with visible aspects of our samples.  Adding an image to the graph is easy
frame << Add Image( image( img ), bounds( top( 600 ), left( 0 ), bottom( 0 ), right( 1200 ) ) )
and I do it a lot.  I am yet to find a way to remove or replace the image with another, say, through a filter change handler.  My current solution is to set up a window with my sample names.  When a sample is selected, the graph display window closes and is relaunched using the image associated with that sample.  I'd love to find a way to simply
frame << Remove Image
or something similar.  Not a dealbreaker, but it would improve the experience and simplify the script.  I'm on JMP 17.1.0.  Thanks!
David_Burnham
Re: How to remove graph image
This seemed to work ... there might be a more elegant way:
cr = current report();
fb = cr[FrameBox(1)];
seg = fb << FindSeg( PictSeg( 1 ) );
seg << remove;
Interactively you can remove the image and the tool tip says it removes the PictSeg; so this code was inspired by the scripting index description of PictSeg.
-Dave
David_Burnham
seg << remove;
-Dave
hogi
Level XIII
Manually, you could remove the image via the right click menu: Image/Remove
mmarchandTSI
Level V
I had overlooked this.  Interesting that the log doesn't capture anything when you remove the image this way.
hogi
Level XIII
@mmarchandTSI wrote:
... Interesting that the log doesn't capture anything when you remove the image this way.
The log is amazingly useful to learn JSL. But you cannot learn everything from the log:
The log provides a script to get B.
It doesn't capture how get get from A to B.
e.g.
You can learn from the log how to generate a graph with a picture in the background - or a graph without such a picture:
just close the graph and the advanced log will show you a JSL script to generate the latest version.
No intermediate changes to the graph are captured. So, it's not possible to learn how a picture is removed.
There are many more steps which are not captured:
https://community.jmp.com/t5/JMP-Wish-List/Workflow-Builder-AddIns/idc-p/614232/highlight/true#M4043
But there is no strict rule - Select matching Cells and Select Where are captured,  Select all rows is not captured.
mmarchandTSI
Level V
Thanks!  This will make the script less jarring to use.  I'll have to remember to use the tooltips to my advantage.
