bp2020
How to recover deleted .jmp file?
I accidentally click "delete" for a .jmp file when opening up the JMP software.  May i know how to recover it?
Thank you.
Re: How to recover deleted .jmp file?
I am not aware of any JMP method to recover the deleted files.
Here  is a URL tutorial on different ways to do it in Windows 10
Some file references are GrayedSome file references are Grayed
Removing a file from the recent file list does not delete the file. The recent file list can have grayed-out references to files that were deleted or moved. If you open a grayed-out file reference, you'll get this dialog
offers to clean up the list of recent filesoffers to clean up the list of recent files
You should check the trash to see if the file landed there, and you should use the file finder to scan your disk to see if the file was moved somewhere (or a network folder perhaps?)
The one in Recent may be another reference, not the actual fileThe one in Recent may be another reference, not the actual file
Did you just delete the reference to the file from the recent files list in the Home Window? That doesn't delete the actual file, just removes it from the list.
bp2020
I delete it on recent file list but the actual files were also somehow deleted...
bp2020
I will try it out. Thank you Craige for the clear explanation.
