sanqub
How to rearrange tables/results in JMP distribution and ultimately create an application in JSL?
Dear All,
Suppose, I have two data sets. I am using standard example Sample library>> Big Class.jmp.
Data set 1: All the 40 students of a class.
Data set 2: Subset of just female students of the the class.
Need: I would like to compare distribution of [age,sex,height,weight] for Dataset 1 and 2.
For this I open both the reports, combine these reports using JMP>file> application. When I combine applications the distribution of age,sex,height,weight are in single window.
But I want in a form age(data set1) and age(data set 2) side by side and in same scale. then height(data set1) and height(data set 2) side by side and in same scale and so on for all other parameters in a single window.
My actual data sets are quiet large and it would be quiet useful when a parameter of data set1 and data set2 are side by side for easier comparison.
Re: How to rearrange tables/results in JMP distribution and ultimately create an application in JSL?
here is a scripting example that gives the results you want
Names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
dt2=open("$SAMPLE_DATA/big class families.jmp");
column list = dt << get column names;
New Window( "Side by Side",
	H List Box(
		For( i = 1, i <= N Items( column list ), i++,
			dt << Distribution( Column( column list[i] ) );
			dt2 << Distribution( Column( column list[i] ) );
6 REPLIES 6
Ultimately you will need all of the data set 1 and data set 2 observations in the same data table. If they start out as separate data tables, then use Tables > Concatenate to bring them together. Make sure that the common variables use the same column names first. Also, make sure that there is a column to indicate membership (i.e., data set 1 or data set 2). If they are already together, then you only need the column for membership. The membership column should use the nominal modeling type.
The Distribution platform freatures should support what you want to do. Select all of the respoinse columns and assign them to Y. Select the membership column and assign it to By role. Examine the red triangle menu: Stack will rearrange the order, Uniform Scaling will make the axes match. You can use the Ctrl-click feature with the red triangle to 'broadcast' the command.
sanqub
Hi Mark,
Thanks for your reply. I have already done it.
But I want the distribution table for a parameter for both data sets just side by side for comparison. {I have 60 input paramters}.
Please check a ppt, results I get by following steps you have mentioned and also what I actual need.
Thanks
San
	H List Box(
sanqub
Hi Txnelson,
Thanks alot.
Thats perfectly what I need. I was really struggling for this since 4days.
 I will try to write in similar fashion to my data sets.
Regards
San
sanqub
Is there a way I can have same scale for the side by side tables so obtained?
Thanks for your help.
OK.....I just checked the date when you joined the community......and you have been online for over a year.........so you already know the answer to your question.......
This is JMP, and of course you can have the axes match. :-)
all that needs to be done is to capture the axis settings from the first graph of the pair, and then copy them to the second graph.
dt2 = Open( "$SAMPLE_DATA/big class families.jmp" );
	H List Box(
			dis1 = dt << Distribution( Column( column list[i] ) );
			dis2 = dt2 << Distribution( Column( column list[i] ) );
			Report( dis1 )[Axis Box( 1 )] << copy axis settings;
			Report( dis2 )[Axis Box( 1 )] << paste Axis settings;
