WebDesignesCrow
How to rearrange column header using JSL script
I want to save my analysis table into Excel file (for others to see).
Because of new columns/ reference column added during my analysis using JMP, I couldn't delete the column before save in Excel.
How can I reorder the column so that those "less important column" for viewers move at the back.
Below is what I want:
Current Column Arrangement
ABCDE
Wanted Column Arrangement
ADEBC
It seems easy but I can't figure out how to do it.
Thanks !
David_Burnham
Re: How to rearrange column header using JSL script
Here is a list of messages that you can use to reorder columns:
https://www.jmp.com/support/help/en/16.1/#page/jmp/rearrange-and-move-columns.shtml?os=win&source=ap...
Check out the scripting index for illustrative examples.
-Dave
David_Burnham
-Dave
