victorsantos
How to "save a report as" automatically in a script?
In my script, I create a control chart and a oneway analysis and I 'd like to save each one as .jpg (JPEG), automatically using the same script.
Re: How to "save a report as" automatically in a script?
Below is an example for launching a Oneway report and saving the result.  The same general procedure can be followed for saving the report from any JMP Platform.
Open("$SAMPLE_DATA/Big Class.jmp");
o=Oneway( Y( :height ), X( :age ) );
(o<<Report) << Save Picture("$DOCUMENTS/Oneway.jpg", "jpg");
I want to do the above thing in loop i.e. that is save a multiple report one after other into picture format?
I am getting an error
Send Expects Scriptable Object in access or evaluation of 'Send' , o << Report
Can you please help me resolve it?
Thanks
Akash
Just to make my question more clear..
For( i=1,i<=3,i++,
Var = Variability Chart(
  Y( :SITE_VALUE ),
  X( :PRODUCT, :DAY, :LOT, :WAFER ),
  Analysis Type( Name( "Choose best analysis (EMS REML Bayesian)" ) ),
  Std Dev Chart( 0 ),
  Mean Diamonds( 1 ),
  Where( dt:Para == pt:Para ),
  Rbox = SendToReport(
  Dispatch( {}, "Variability Chart for SITE_VALUE", OutlineBox, Set Title( Title ) ),
  Dispatch(
  {"Variability Chart for SITE_VALUE"},
  "2",
  ScaleBox,
  {Format( "Fixed Dec", 12, 3 ), Min( pt:LL - 0.1*pt:LL ), Max( (pt:UL + 0.1*pt:UL) ), Inc( 0.1*pt:Target ), Add Ref Line( 0, Dotted, "Medium Light Gray" ),
  Add Ref Line( pt:Target, Solid, "Black" ), Add Ref Line( pt:UL, Solid, "Medium Dark Fuchsia" ), Add Ref Line(
  pt:LL,
  Solid,
  Dispatch( {"Variability Chart for SITE_VALUE"}, "", NomAxisBox, Rotated Tick Labels( 1 ) ),
  Dispatch( {"Variability Chart for SITE_VALUE"}, "", NomAxisBox( 2 ), Rotated Tick Labels( 1 ) ),
  Dispatch( {"Variability Chart for SITE_VALUE"}, "", NomAxisBox( 3 ), Rotated Tick Labels( 1 ) )
Rbox = Var <<Report ;
Rbox << save picture("Temp",jpeg);
// Above code runs just fine for single iteration but for more iteration it gives error
//Send Expects Scriptable Object in access or evaluation of 'Send' , Var << get scriptable
// I am new JMP and using JMP 8 (thats what we have here)
// My ultimate aim is to import the generated files into a ppt. For which I am thinking of using Powerpoint Macro
Please help to resolve.
Thanks in advance
Akash
