mystylelife19
How to put value in spec limit column properties
Hi community, i'm trying my best to solve this but i failed again & again. Can someone tell me where is my mistake?
I want to put value text box in the spec limit column properties? I already tried so many times. If i
change
 {LSL(LowL), USL(HighL), Show Limits( 2 )}
into
 {LSL(500), USL(1000), Show Limits( 2 )}
it worked. But i don't want number, i want value in LowL & HighL.
Here my full script
// Get the all column names from the data table
columnNames = dt << Get Column Names("String");
// Choose the specific column
cl = New Window("Column Selection", <<Modal,
    HListBox(
		  Panel Box("Make a selection",
			VlistBox(
			  usropt = RadioBox(columnNames,
			     prmtr=usropt<<get
//Text Box Put value spec limit Upper & Lower
wd = New Window( "Spec Limit", << modal(),
	hlistbox(
		Text Box( "HighL:" ),
		High_Limit = Text Edit Box( "",<<set width( 90 ) ),
	Button Box( "OK",
		HighL = High_Limit << get number();
	hlistbox(
		Text Box( "LowL:" ),
		Low_Limit = Text Edit Box( "",<<set width( 90 ) ),
	Button Box( "OK",
		LowL = Low_Limit << get number();
//Put value Spec Limit on choosen column
col = Column(prmtr);
col << Add Column Properties(
    Set Property(
    "Spec Limits",
mystylelife19
Re: How to put value in spec limit column properties
UPDATE!!!
After research all the topic in this community i already solve this with research apply all the method given every solution given. Thank god i solve this with helper from god. Alhamdulillah
Here my scripts
// Open a data table or replace "Data Table Name" with the name of your data table
    HListBox(
			VlistBox(
			  allcolumn = RadioBox(columnNames,
			     prmtr=allcolumn<<get
	hlistbox(
		High_Limit = Number Edit Box( "",<<set width( 10 ) ),
	Button Box( "OK",
		HighL=High_Limit<<get;
// If cancel or X was clicked, stop the script
If( wd == {Button( -1 )}, Stop() );
	hlistbox(
		Low_Limit = Number Edit Box( "",<<set width( 10 ) ),
	Button Box( "OK",
		LowL=Low_Limit<<get;
Eval(
	Substitute(
			Expr(
				Set Property(
				"Spec Limits",
				Eval(	{LSL(low), USL(high), Show Limits( 2 )})
	Expr(low), LowL,
	Expr(high), HighL
You will have to evaluate the values Insert one expression into another using Eval Insert, Eval Expr, Parse, and Substitute . One option is something like this
Eval(EvalExpr(
		Set Property(
			"Spec Limits",
			{LSL(Expr(LowL)), USL(Expr(HighL)), Show Limits(2)}
mystylelife19
Still did not work for me. The value from text box did not getting into the spec limit.
This does work for me
	<<Modal,
	H List Box(
			V List Box(allcolumn = Radio Box(columnNames, prmtr = allcolumn << get))
wd = New Window("Spec Limit",
	<<modal(),
	H List Box(Text Box("HighL:"), High_Limit = Number Edit Box("", <<set width(10)), ),
	Button Box("OK", HighL = High_Limit << get)
If(wd == {Button(-1)}, Stop());
	<<modal(),
	H List Box(Text Box("LowL:"), Low_Limit = Number Edit Box("", <<set width(10)), ),
	Button Box("OK", LowL = Low_Limit << get)
Eval(EvalExpr(
		Set Property(
			"Spec Limits",
Also if you would like to, you could combine all those selections into a single modal window
col_names = dt << Get Column Names("String", Continuous);
nw = New Window("Set Specs", << Modal,
	H List Box(
		Panel Box("Select Column",
			rb_col = Radio Box(col_names)
		Panel Box("Select Limits",
			Lineup Box(N Col(2),
				Text Box("LSL: "),
				lsl_neb = Number Edit Box("", <<set width(10)),
				Text Box("USL: "),
				usl_neb = Number Edit Box("", <<set width(10))
		Panel Box("Actions",
			Lineup Box(N Col(1),
				Button Box("OK",
					lsl_val = lsl_neb << get;
					usl_val = usl_neb << get;
					sel_col = rb_col << get selected;
				Button Box("Cancel")
If(nw["Button"] != 1,
	Throw("Cancel pressed");
show(sel_col, lsl_val, usl_val);
mystylelife19
UPDATE!!!
Here my scripts
    HListBox(
			VlistBox(
	hlistbox(
	Button Box( "OK",
	hlistbox(
	Button Box( "OK",
Eval(
	Substitute(
			Expr(
				Set Property(
				"Spec Limits",
	Expr(low), LowL,
	Expr(high), HighL
