How to overlap points with the same/ very close values in a graph?
Hello!
A quick question, as the title suggests, how can I overlay points with the same value or close values ( e.g., a difference smaller than 0.1) in a graph?
For example, in the following situtation I want to keep only one point for each small range of values, and therefore lose the observed horizontality of points.
Thank you very much in advance.
Re: How to overlap points with the same value in a graph?
In the control panel of graph builder, find the section that says Jitter and change the setting from Auto to None.
Dan Obermiller
Thank you! :D
