Hobbi
How to order the x-axis of a Oneway Analyis by another column?
Hey all,
I have a typical JSL that makes graphs from a table with X-Y Oneway Analysis that defaults to ordering the X axis alphabetical/numerical.
On my graphs I want the top most value(in the table) to be the furthest to the right on my plots. I have been right clicking then "Edit Value Order" to do this, but I would like to incorporate it in my JSL for my colleagues to be able to use as well.
I went into Scripting help but was lost as to how I would set Row Order Levels in JSL.
Re: How to order the x-axis of a Oneway Analyis by another column?
You can see how to set the different Column Properties by setting them interactively, and then using
     << get Property()
retrieve what is required to use
     << set Property()
to use JSL to assign the values
So I set the order for the lot_id column interactively
I then ran this script to get the structure required for the Value Ordering column property
names default to here(1);
dt=current data table();
orderList = dt:lot_id << get property("Value Order");
show(orderList);
it returned
orderList = {Custom Order({"lot09", "lot08", "lot07", "lot06", "lot05", "lot04", "lot03", "lot02", "lot01", "lot10", "lot11", "lot12", "lot13"}), Common Order(0)};
Therefore, the JSL required to set the Value Order property is
dt:lot_id << set property("Value Order", {Custom Order({"lot09", "lot08", "lot07",
"lot01", "lot10", "lot11", "lot12", "lot13"}), Common Order(0)});
ron_horne
Hi @Hobbi ,
@txnelson gave you the exact correct answer.
Yet, the best ordering options for an axis in a graph are available in Graph builder. There, you can order a categorical axis by a variety of summary statistics of other variables. as in the pictures.
Let us know if it works in for your application.
