How to open this JSON file as a data table?
I need help with opening this JSON file in JMP as a data table: https://www.purpleair.com/data.json
I used JMP's JSON Import Wizard, but have not been able to open the file in a way that I want to.
I'd like the 'fields' to be the column headers and 'data' to be the rows in the data table. I appreciate your help in advance.
Re: How to open this JSON file as a data table?
Most likely there are better ways to handle this, but here is one possible solution (requires JMP16 due to For Each):
s = New HTTP Request(
	url("https://www.purpleair.com/data.json"),
	Method("GET"),
	Headers({"Accept: application/json"})
) << Send;
aa_json = Associative Array(Parse JSON(s));
//aa_json << get keys;
//aa_json["fields"];
//Create collection table and columns
dt = New Table("json");
For Each({new_col}, aa_json["fields"],
	dt << New Column(new_col);
Column(dt, "Label") << Data Type("Character"); //character columns must be set "manually"
//Fill rows
row_count = N Items(aa_json["data"]);
dt << Add Rows(row_count);
dt[0,0] = aa_json["data"];
Write(); //empty Write() to avoid printing all values to log
	Method("GET"),
) << Send;
//Fill rows
nice!
Thanks a lot @jthi !
