I thought I would post this in case someone found it useful. Another possible way to achieve this is by creating a new data table with the processes stacked and the missing values removed from the stacked table. Then you can use the Grouping column in Process Screening to split the table into separate processes. (Note you also will have to create a spec limits table to use this method if you want the capability calculations since the column properties will disappear in the stacked table. ) The following JSL demonstrates how to do this:
dt = Data Table("Process Screening Example");
dtStack = dt << Stack(
columns(
:Characteristic One,
:Characteristic Two,
:Characteristic Three,
:Characteristic Four,
:Characteristic Five,
:Characteristic Six,
:Characteristic Seven,
:Characteristic Eight,
:Characteristic Nine,
:Characteristic Ten,
:Characteristic Eleven,
:Characteristic Twelve
Source Label Column( "Label" ),
Stacked Data Column( "Data" ),
Output Table( "Stacked Process Screening Example" )
dtStack << select where (isMissing(:Data));
dtStack << delete rows;
obj = dt<< Manage Spec Limits(
Y(
dtLimits = obj << Save to Tall Spec Limits Table;
obj2 = dtStack << Process Screening(
Y( :Data ),
Grouping( :Label ),
Control Chart Type( "Indiv and MR" ),
Use Limits Table(
1,
dtLimits,
Grouping( :Variable ),
LSL( :LSL ),
USL( :USL ),
Target( :Target ),
Go
obj2 << select all;
obj2 << control charts for selected items;
If you just want to do the same thing with Control Chart Builder without launching Process Screening first, you can use the following JSL:
columns(
obj = dtStack << Control Chart Builder( Variables( Y( :Data )), By( :Label ) );
