shampton82
How to minimize a floating global filter window
Hey everyone,
I am having an issue trying to find a way to minimize a floating global data filter window.  I have tried <<show window(0) and <<minimize window(1) and neither seem to work.
Any ideas on what syntax to use?
Thanks for any input!
Steve
mmarchandTSI
Level V
Re: How to minimize a floating global filter window
You can do it this way.
Current Data Table() << Data Filter(
	Location( {780, 189} ),
	Conditional,
	Add Filter(
		columns( :Date Time Quarter, :Date Time Period, :Date Time ),
		Display( :Date Time Quarter, N Items( 5 ) ),
		Display( :Date Time Period, N Items( 5 ) )
	Show Window( 0 )
Show Window(0) works for me
dt << Data Filter();
wait(1);
windows = Get Window List() << get window title;
For Each({window}, windows,
	If(Starts With(window, "Data Filter for"),
		Window(window) << Show Window(0);
		break();
shampton82
@jthi So weird!  I'm using this script in a work flow:
	Conditional,
	Add Filter(
)<<show window(0);
This creates the filter but won't hide it.
Maybe you just need extra pair of brackets
(dt << Data Filter()) << Show Window(0);
or if you want to get a reference something like this
Local({filter_ref},
	filter_ref = dt << Data Filter();
	filter_ref << Show Window(0);
shampton82
Hey @jthi , I don't know why but the top method did not work when I tired it in my script but it works just fine when I run the provide script on its own.  I haven't had a chance to try out the second method in my script but I'll give an update when I can.  For some reason the proposed solution by @mmarchandTSI worked......
mmarchandTSI
Level V
	Conditional,
	Add Filter(
	Show Window( 0 )
