ac11ca
How to manipulate axes scales in Graph Builder when using log units
Please see attached data file.
I am trying to plot "actual" vs. "perceived" separated by "context". I have created a graph doing this and saved the script as "Graph - Perceived ~ Actual x Context".
(1.png)
The data is skewed so I created via the formula function two new variable by logging both "actual" vs. "perceived". I then created a new graph and saved the script as " Graph - Ln(Perceived ) ~ Ln(Actual) x Context".
(2.png)
This new figure gives me the shape I want but the axes are not interpretable. How do I create axes that operate on the original raw numbers and create a graph that has axes like the following:
(3.png)
Basically, how do I draw a figure that logs the data of the x and y axes but presents the data in the original units, rather than log units?
Thanks.
Adrian
ms
Super User (Alumni) ms
Re: How to manipulate axes scales in Graph Builder when using log units
Make the plot with untransformed data and dubbelclick on an axis to bring up the axis specification dialog and change the scale setting from linear to log.
ms
ac11ca
Also:
analyze -> fit Y by X
perceived = Y
actual = X
Click OK
red triangle -> group by -> context
red triangle -> fit special
Change Y transformation to natural log
Change X transformation to natural log
Change degree from 1 Linear to 2 Quadratic
Click OK
Double click the Y axis and change the scale from linear to log Double click the X axis and change the scale from linear to log
