jconte
How to make recursive function with associative array as parameter
I'm trying to parse a nested associative array in JMP 16 (extracted from a JSON). The basic structure of the JSON is as follows:
"groupOp": "&", "rules": [ {"column": "col1", "op": "==", "value": 1}, {
"groupOp": "|",
"rules": [
{"column": "col2", "op": "==", "value": 2}
{"column": "col3", "op": "==", "value": 3}
This would allow structured storage of the nested condition "col1 == 1 & (col2 == 2 | col3 == 3)", and others of arbitrary depth.
I wrote a recursive function to parse this structure, using the contains function to distinguish the base case from the recursive case. However, I'm running into a stack overflow error. Upon debugging I realized that while "rule" had the correct value, "obj" stayed the same on each recursive call.
parseFilter = Function( {obj},
	If (obj << contains("groupOp") & obj << contains("rules"),
		str = "(";
		For Each({rule}, obj["rules"],
			show(rule);
			Concat(str, Recurse(rule) || " " || groupOp || " ");
		Concat(str, ")");
		Return(str);
	, // else
		Return(":" || obj["column"] || " " || obj["op"] || " " || data );
 Is this to do with the For Each function, having an associative array as a parameter, or something else?
Re: How to make recursive function with associative array as parameter
Without studying too deep, the first change you probably need is to make str be local. Change
to
parseFilter = Function( {obj},{str},
It looks like another parameter list, but it is actually a list of variables that are local to the function, and to each recursive call of the function.
jconte
Thanks for the tip. Still running into the same issue though.
I think this might be what you are after. Untested code follows...
json =
  "groupOp": "&",
  "rules": [
      "groupOp": "|",
      "rules": [
        {"column": "col2", "op": "==", "value": 2},
	{str, first},
	If( obj << Contains( "groupOp" ) & obj << Contains( "rules" ),
		str = "(";
		first = 1;
		For Each( {rule}, obj["rules"],
			If( first,
				first = 0;
			,// else
				str ||= (" " || obj["groupOp"] || " ")
			str ||= Recurse( rule );
		str ||= ")";
		Return( str );
	, // else
		Return( ":" || obj["column"] || " " || obj["op"] || " " || Char( obj["value"] ) )
Write( parsefilter( Parse JSON( json ) ) );
(:col1 == 1 & (:col2 == 2 | :col3 == 3))
