RonnieOmics
How to make proper confidence interval plots? I tried making them using a tutorial I found here but I cannot make them appear. Why?
Hi. I am lost here. I tried making interval plots and I cannot see them in the graph I made. Can anyone help me?
P_Bartell
Level VIII
Re: How to make proper confidence interval plots? I tried making them using a tutorial I found here but I cannot make them appear. Why?
Confidence interval plots are in many, many different locations in the JMP ecosystem, for different things like parameter estimates, prediction intervals, and on and on. Perhaps if you shared your data, even anonymized and the specific platform you are attempting to use, and the specific type of interval, one of us can help?
statman
As Pete indicates, there is no way to know what is happening unless you provide more context.  Often the data table is not setup correctly.
