BabyDoragon
How to make group X display only certain items.
When using Group X, all sections are cut out in the table. How should I modify the following JSL so that Group X only displays 13 and 16?"
Graph Builder(
	Size( 528, 500 ),
	Show Control Panel( 0 ),
	Variables( X( :sex ), X( :age, Position( 1 ) ), Y( :height ), Group X( :age ) ),
	Elements( Points( X( 1 ), X( 2 ), Y, Legend( 10 ) ) )
Re: How to make group X display only certain items.
You could add local data filter if something like this what you are looking for
Graph Builder(
	Size(528, 500),
	Show Control Panel(0),
	Variables(X(:sex), X(:age, Position(1)), Y(:height), Group X(:age)),
	Elements(Points(X(1), X(2), Y, Legend(10))),
	Local Data Filter(
		Add Filter(
			columns(:age),
			Where(:age == {13, 16}),
			Display(:age, N Items(6))
Or if you are scripting, you can use Where
gb = dt << Graph Builder(
	Size(528, 500),
	Where(Contains({13, 16}, :age))
Just switch the logic by using not "!"
	Size(528, 500),
	Where(!Contains({13, 16}, :age))
Graph Builder(
	Size(528, 500),
	Local Data Filter(
		Add Filter(
			columns(:age),
	Size(528, 500),
BabyDoragon
In the second method you mentioned, it is a positive list, show only 13 and 16.
However, is it possible to make it a negative list, for example, ignoring 17 in any situation.
	Size(528, 500),
