TDK_Long
How to make a plot of scatter with lines and markers like Excel?
Hi folks,
I am having a hard time of duplicating an Excel plot of scatter with lines and markers in JMP. The Excel table and plot is shown below as an example:
I know we need to format the data table in JMP, I did the following data table, but still cannot plot the scatter with lines and markers. , could anyone advise how can I do it in JMP? Thanks.
stan_koprowski
Re: How to make a plot of scatter with lines and markers like Excel?
Hi @TDK_Long
Right-Click on the graph and click customize to change the maker shape.
Graph Builder CustomizeGraph Builder CustomizeGraph Builder Change Marker ShapeGraph Builder Change Marker Shape
Right-Click on the axis to add grid lines
Axis Settings Add Grid LinesAxis Settings Add Grid Lines
Graph Builder Line with customized markerGraph Builder Line with customized marker
Does this help?
cheers,
Stan
stan_koprowski
Hi @TDK_Long
Does this help?
cheers,
Stan
TDK_Long
Hi Stan,
I have a problem at the first step. How do you create the two lines? I cannot connect the three points as shown below. Could you use the attached jmp file to see what I am missing? Thank you.
Level XIII
Drag Group onto the Overlay dropzone. That's it.
[x on x, y on y]:)
If you want to connect the lines instead of a smoother, just switch from smoother to "Line":
by right-clicking on the legend, you can adjust the colors and markers.
and via the red triangle menu, you can specify the legend position to be at the bottom.
TDK_Long
Hi Hogi,
Thanks for the tips. Now I understand it. Much appreciated.
