How to load a very large database
AliSheffeh
I'm trying to load a very large database using JMP but I'm running out of memory. It contains almost 1k columns and millions of rows. The file size is almost 35 GB. Is there any way that I can open only selected columns to minimize memory usage? Any recommendations on how to open such a large file using JMP? Unfortunately, I don't have coding experience
11 REPLIES 11
Re: How to load a very large database
Using
    File=>Database=>Query Builder
you should be able to select only the columns you want, from the tables you want
I suspect, other Community Members may have additional suggestions.
mmarchandTSI
To add to Jim's post, Query Builder allows you to sample x% of the rows or choose the first (or random) x rows, as well.
AliSheffeh
I have the data as .csv file. I couldn't open it using query builder
AliSheffeh
Thanks, I have the data as .csv file. Is there a different way to open it? Or I need to upload the file to a specific server and then do query builder?
You could also try Select Columns when you open the file
Script created by it
Open("$SAMPLE_DATA/Big Class.jmp", Select Columns("name", "age", "height"));
This will let you limit the column selection, but I'm not sure if it will work for you.
Open also has other options to limit the data, you can open first x rows, last x rows or random x rows
dt = Open("$SAMPLE_DATA/CrimeData.jmp", First(10));
dt = Open("$SAMPLE_DATA/CrimeData.jmp", Random(10));
dt = Open("$SAMPLE_DATA/CrimeData.jmp", Last(10));
and instead of selecting specific columns, you can ignore specific columns
dt = Open("$SAMPLE_DATA/Big Class.jmp", ignore columns("age"));
One of the Open items in scripting index has some of these examples
AliSheffeh
I appreciate your effort in putting together this comprehensive explanation. The first option does not work unless the file is a JMP file. I've tried all other options and it's not executing the second part of the code. It only opens the file without selecting or ignoring the specific columns I want. I've tried the example you provided and it worked but when I choose the file I want, the select or ignore function does not work.
You can edit the script that imports the file to omit columns and subset the data.
importText.mp4
Video Player is loading.
Current Time 0:00
Duration 1:13
Loaded: 13.55%
Stream Type LIVE
Remaining Time 1:13
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • default, selected
    (view in My Videos)
    AliSheffeh
    Thanks! It worked for me
    mmarchandTSI
    Ah, it's a .csv file.  Use "Open" and choose the "Data (Using Preview)" option.
    Then choose your subset preferences.
