Kevin
How to join tables with time interval
I am working to join two tables, table 1 has time stamped data, and table 2 has start time and end time of each phase and cycle. I would like to join two tables so that table 1 can have phase and cycle columns.
Appreciate if anyone can show me how.
Thanks
Re: How to join tables with time interval
I would most likely try using SQL query with JMP tables. You can do this with Query()
dt1 = Open("$DOWNLOADS/table1.jmp", Invisible);
dt2 = Open("$DOWNLOADS/table2.jmp", Invisible);
dt3 = Query(
	Table(dt1, "t1"),
	Table(dt2, "t2"),
	"\[SELECT *
       FROM t1
       left join t2 on t1.'Time' >= t2.'Start Time' and t1.'Time' <= t2.'End Time'
