Tavuk89
Merge multiple tables corresponding to different column in main table
I have main table and multiple others that I would like to join with that.
The main table has column A that corresponds to first table,
column B that corresponds to 2nd table
column C that corresponds to 3rd table
These tables also have columns with same name, so I don't want to merge column with same name together.
I usually join these tables one by one. How do I join them at once? I don't know how to write jsl script..
Re: Merge multiple tables corresponding to different column in main table
I suggest that you take each of your interactive Join steps, and place them into a JMP Workflow.  Then once it is built, all you have to do is to run the Workflow whenever you need to join the tables.
Tavuk89
Thank you but I'm still at JMP 16
But I learnt jsl scripts and scripted them all :)
