jump
How to join\Update Multiple data tables using same Match ID
hi,
i am trying to join multiple data tables  using same match id.
update_table= Data Table( PS1(ma) " ) << Update(
  With( Data Table( "PS2(ua) ")),
  With( Data Table( "PS3(ua) ")),
With( Data Table( "PS4(ua) ")),
  Match Columns( :match_col = :match_col ),
  output table name("FINal")
above code only updates\joins very first table and ignores rest.
Is there a way to join\update multiple tables at same time.
Also, is there a way to use data table reference\handle to join or update tables instead of using  Data table name.
thx
ms
Super User (Alumni) ms
Re: How to join\Update Multiple data tables using same Match ID
Update (and Join) cannot not handle multiple tables as far as I know. I'd use a loop in this situation, for example:
tablenames = {"PS2(ua) ", "PS3(ua) ", "PS4(ua) "};
For( i = 1, i <= N Items( tables ), i++,
  Data Table( "PS1(ma) " ) << update( with( Data Table( tablenames[i] ) ) )
ms
jump
Hey MS,
thanks ..that is a good idea.
btw .. can we use table reference\handle instead of data table name. I have tried but it not working for me.
thx
ms
Yes, it is possible. You can address a table using its name, number (e.g. Data Table(1)) or a defined variable. Below is an example using variables dt1 and dt2 that refer to data tables.
path = "$SAMPLE_DATA/"; // Path to directory of your data tables
tables = Files In Directory( path )[1 :: 3]; // Here limited to first 3 files because example dir is huge
dt1 = Open( "$SAMPLE_DATA/Big Class.jmp" );
For( i = 1, i <= N Items( tables ), i++, //
  If( Ends With( tables[i], ".jmp" ), // Test that file i is a data table
  dt2 = Open( path || tables[i] );
  dt1 << update( with( dt2 ) );
  Close( dt2, no save );
