Jiaxiang
How to insert a column with specified column index with JMP script?
I met a problem when writting my JMP script, I want to add the new column with a formula Y/X but there are serveal colunms and I want to add the new colunm after specified column,
For example:
A Table like:
A    B    C    D
1    2     3    4
2    4     6    8
and I want to add a new column after B column(like below), but the B/A column will always after D when I use New Column function, and I cannot find a good function from the scripting index , how to insert a column to a specified column index?
<<New Column("B/A",formula(:B/:A));
A    B   B/A   C    D
1    2      2     3    4
2    4      2     6    8
Re: How to insert a column with specified column index with JMP script?
Use the
<< Move Selected Columns()
message to move the new column to where you want it
// Open Data Table: big class.jmp
// → Data Table( "big class" )
// New column: Column 6
dt << New Column( "Column 6",
	Numeric,
	"Continuous",
	Format( "Best", 12 )
) << Move Selected Columns( {:Column 6}, after( :sex ) );
or
	Numeric,
	"Continuous",
dt << Move Selected Columns( {:Column 6}, after( :sex ) );
