Greeny
How to include greek letters when editing axis title (without changing column name)
Is there a way to insert a Greek letter and special character when editing the axis title of a graph, without changing the column name in the data table?
Thanks in advance.
Re: How to include greek letters when editing axis title (without changing column name)
You can use the Unicode characters, see JMP Help
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
Open( "/C:/Program Files/SAS/JMPPRO/17/Samples/Data/Big Class.jmp" );
Graph Builder(
	Variables( X( :weight ), Y( :height ) ),
	Elements( Points( X, Y, Legend( 5 ) ), Smoother( X, Y, Legend( 6 ) ) ),
		Dispatch( {}, "Y title", TextEditBox, {Set Text( "\!U03C3 height" )} )
Level XII
On a Windows Computer you can click Win + Point to open the Emoji Shortcut panel.
The panel also provides a section with Greek letters.
Fortunately, the greek letters will be displayed correctly.
Next question: what's the issue with the Emojis ?!?!
Graph Builder(
Greeny
Thanks, but I was wondering if it is possible to insert the greek letter while manually editing the axis title (without JSL).
I am not aware of how to enter the Unicodes interactively, so that JMP recognizes them.  Maybe another Community Member does.
Level XII
Greeny
That worked perfectly. Another super helpful response from you, two days in a row! Thanks so much.
