NGC_DAquila
Graph Exporting
I am using a Local Data Filter to change my graph but i want it to iterate through each of the "switchers" and print each onto a powerpoint slide. Is this possible in JMP18?
Re: Graph Exporting
You can use similar idea than you can with column switcher with the exception that data filters are more complicated to manipulate. Below is one option
gb = dt << Graph Builder(
	Size(525, 454),
	Show Control Panel(0),
	Variables(X(:weight), Y(:height), Overlay(:sex)),
	Elements(Points(X, Y, Legend(9)), Line Of Fit(X, Y, Legend(11))),
	Local Data Filter(
		Add Filter(columns(:age), Display(:age, N Items(6)))
Summarize(dt, items = By(:age));
lbb = (Report(gb) << top parent)["Local Data Filter", ListBoxBox(1)];
pptx_loc = "$TEMP/powerpoint_test.pptx";
gb << Save Presentation(pptx_loc);
For(i = 1, i <= N Items(items), i++,
	lbb << Clear Selection;
	lbb << Set Selected(i);
	gb << Save Presentation(pptx_loc, Append);
	wait(0);
// Web(pptx_loc);
Write();
But have you consider using Page instead of Local Data Filter? It is much simpler
	Variables(X(:weight), Y(:height), Overlay(:sex), Page(:age)),
// Web(pptx_loc);
Write();
Re: Graph Exporting
	Size(525, 454),
	Local Data Filter(
	wait(0);
// Web(pptx_loc);
Write();
// Web(pptx_loc);
Write();
statman
Re: Graph Exporting
All you have to do is save each graph to the JMP Journal (ctrl>j).  Once you have all of the versions of the graphs in the journal, open the journal and export to PowerPoint.
