AlexR846
How to include code to show the Grid Lines in the Variability plot for X-Axis?
There is a list named "ColumnsList" with columns name from my Datatable for which i would like to make Variability plot for all columns present in the list.
Following Script creates box plots for all columns as required in the single page,
theExpr = "Variability Chart( Y( :\!"" || ColumnsList[1] || "\!"";
For( p = 2, p <= N Items( ColumnsList ), p++,
   theExpr = theExpr || ", :\!"" || ColumnsList[p] || " \!"");
theExpr = theExpr || "), X(:WaferID, :DateCode, :Die),Std Dev Chart( 0 ),Show Grand Mean( 1 )";
Eval( Parse( theExpr ) );
However, for me it is bit challenging to include a code snippet to include the "Show Major Grid" for X-Axis in the above script.
Could anyone help me, how to include code snippet to show the Major Grid Line in the above code.
Thank you.
Alex.
Re: How to include code to show the Grid Lines in the Variability plot for X-Axis?
Maybe something like this:
dt = Open("$SAMPLE_DATA/Variability Data/2 Factors Crossed.jmp");
var_chart = dt << Variability Chart(
	Y(:Measurement, :Standard), X(:Operator, :part#),
	Std Dev Chart(0),
	Show Grand Mean(1)
For Each({rep}, var_chart << report,
	axisbox = rep[axis box(2)];
	axisbox << Show Major Grid(1);
	Std Dev Chart(0),
	Show Grand Mean(1)
AlexR846
Thanks Jarmo !!
That perfectly did the job.
