JMPPRO
How to grey out OK button if user input is missing
I am creating a modal window with "Ok" and "Cancel" button. How can I leave the "Ok" button greyed out if the user did not enter any information in one of the inputs?
Thank you.
// User Interface Window to get some data
UIwin = New Window( "User Input",
	Show Menu( 0 ),
	Show Toolbars( 0 ),
	<<Modal,
	H List Box(
		V List Box(
			Panel Box( "",
					Spacer Box( size( 250, 5 ) ),
					H Center Box( Text Box( "User Input 1", <<Set Font Size( 11 ) ) ),
					H Center Box( String1 = Text Edit Box( "", Hint( "User Input 1" ), <<set width( 150 ) ) ),
					Spacer Box( size( 5, 5 ) ),
					H Center Box( Text Box( "User Input 2", <<Set Font Size( 11 ) ) ),
					H Center Box( String2 = Text Edit Box( "", Hint( "User Input 2" ), <<set width( 150 ) ) ),
					Spacer Box( size( 2, 25 ) ),
			Button Box ("OK",
			UserInput1 = String1 << get text();
			UserInput2 = String2 << get text();
		Button Box ("Cancel", UIwin),
ih
Super User (Alumni) ih
Re: How to grey out OK button if user input is missing
You could use the Enable() message, like this:
names default to here(1);
CheckInput = function({},
	write("here");
	if(
		(length(UserInput1) > 0 ) & (length(Userinput2) > 0),
		bbOK << Enable(1),
		bbOK << Enable(0)
	Show Menu( 0 ),
	Show Toolbars( 0 ),
	<<Modal,
	H List Box(
		V List Box(
			Panel Box( "",
					H Center Box( String1 = Text Edit Box( "", Hint( "User Input 1" ), <<set width( 150 ), << Set Script( CheckInput() ) ) ),
					H Center Box( String2 = Text Edit Box( "", Hint( "User Input 2" ), <<set width( 150 ), << Set Script( CheckInput() ) ) ),
			bbOK = Button Box ("OK",
			, << Enable(0)
ih
	write("here");
	if(
		bbOK << Enable(1),
		bbOK << Enable(0)
	Show Menu( 0 ),
	Show Toolbars( 0 ),
	<<Modal,
	H List Box(
		V List Box(
			Panel Box( "",
			, << Enable(0)
