Neo
Neo
How to get y-axis labels from multiple Y charts and change only specific labels?
In a multiple y plot, how can I get the plotted y-axis labels/tiles (e.g. say get AAA, BBB, CCC, DDD and FFF as a list) and change some specific ones (post plotting), say BBB and DDD to BBB1 and DDD1 respectively and replot (closing the old)?
When it's too good to be true, it's neither
Re: How to get y-axis labels from multiple Y charts and change only specific labels?
One option is to use << Get Legend Display and its items
gb = Graph Builder(
	Variables(X(:height), Y(:weight), Overlay(:sex), Color(:age)),
	Elements(Points(X, Y, Legend(1)), Smoother(X, Y, Legend(2)))
lgnd = gb << Get Legend Display;
items = lgnd << Get Items;
For Each({item}, items,
	If(Contains({"12", "14"}, item << get label),
		item << Set label(Repeat(item << get label, 3))
Neo
Neo
@jthi Thanks. I am afraid, I do not follow. Perhaps I did not explain the case correctly.
I want to capture the existing y-axis labels in a multiple y-axis plot, say in a list and then change specific ones to desired label names and replot.
ah.. I though you want to modify legend. Axis labels seem to be one of the annoying things (you can remove them and add new, but I'm not exactly sure how to get current label). So XPath to rescue like usually (might be a good idea to filter out graph title and possibly x-axis)
gb = dt << Graph Builder(
	Size(528, 454),
	Show Control Panel(0),
	Variables(X(:height), Y(:height), Y(:weight)),
	Elements(Position(1, 1), Points(X, Y, Legend(3))),
	Elements(Position(1, 2), Points(X, Y, Legend(1)))
rep = Report(gb);
tebs = rep << XPath("//GraphBuilderTitleBox/TextEditBox");
For Each({teb}, tebs,
	cur_title = teb << get text;
	show(cur_title);
	If(cur_title == "weight",
		teb << Set Text(Repeat(cur_title, 2))
