UserID16644
Level V
How to get value of duplicate columns?
Hi all,
How can I get the value of a Column A and place it with the duplicate value in Column B?
For example, this is my data:
Column A Column B
A Apple
  Apple
B Banana
  Mango
C Mango
This is the expected output:
Column A Column B
A Apple
A Apple
B Banana
C Mango
C Mango
Re: How to get value of duplicate columns?
If you sort your data where the non blank value of Column A is always first, and then select all Column A rows
You can right click on the value for row 1 for Column A and select
Here is a alternative JSL solution
// Create the sample data table
dt = New Table( "Example",
	Add Rows( 5 ),
	New Column( "Column A",
		Character,
		"Nominal",
		Set Values( {"A", "", "B", "", "C"} )
	New Column( "Column B",
		Character,
		"Nominal",
		Set Values( {"Apple", "Apple", "Banana", "Mango", "Mango"} )
// Sort the table to allow non black Column A rows to be first
dt << Data Table( "Example" ) << Sort(
	By( :Column B, :Column A ),
	Order( Ascending, Descending ),
	Replace Table( 1 )
// Modify the Column A
Hold = "";
For Each Row(
	If( :Column A != "",
		Hold = :Column A,
		Show( Lag( :column b ), :column b );
		If( Lag( :Column B ) == :Column B,
			:Column A = Hold
pmroz
Here's another approach that uses the tabulate platform.  Sorting is not requred.
dt = New Table( "Test", Add Rows( 5 ),
	New Column( "Column A", Character, "Nominal",
		Set Values( {"A", "", "B", "", "C"} ) ),
	New Column( "Column B", Character( 16 ), "Nominal",
		Set Values( {"Apple", "Apple", "Banana", "Mango", "Mango"} ) )
dtab = dt << Tabulate(
	Show Control Panel( 0 ), invisible,
	Add Table( Row Table( Grouping Columns( :Column A, :Column B ) ) )
dt2 = dtab << Make Into Data Table (invisible);
dtab << close window;
for (i = 1, i <= nrows(dt2), i++,
	one_key = dt2:Column B[i];
	one_value = dt2:Column A[i];
	rowset = dt << get rows where(dt:Column B == one_key & dt:Column A == "");
	dt:Column A[rowset] = one_value;
close(dt2, nosave);
