AT
AT
How to get the UCL value for Outlier analysis in a script?
I like to write a script to get the UCL for multivariate outlier analysis using Mahalanobis Distance.
I can get the UCL by going through the JMP menu but is there anyway one can get UCL and set it to variable name in a script.
I appreciate your hlep. Thanks.
cwillden
Re: How to get the UCL value for Outlier analysis in a script?
Hi @AT,
It seems a little tricky to lift this value from the report, but you could get at it by scripting the "Save Outlier Distances" action and then pulling out the column property "Mahal. Value" that results from that action.  It's not too difficult to get column property values saved as variables.  Here's an example using the Thickness sample data set:
dt = Open("$SAMPLE_DATA/Quality Control/Thickness.jmp");
multi = dt << Multivariate(
	Y(
		:Thickness 01,
		:Thickness 02,
		:Thickness 03,
		:Thickness 04,
		:Thickness 05,
		:Thickness 06,
		:Thickness 07,
		:Thickness 08,
		:Thickness 09,
		:Thickness 10,
		:Thickness 11,
		:Thickness 12
	Estimation Method( "Row-wise" )
multi << Mahalanobis Distances( 1 , Save Outlier Distances);
mahal_ucl = Column("Mahal. Distances") << Get Property("Mahal. Value");
However, this limit is actually really easy to compute in a function.  It's just the square root of the the UCL in a Hotelling's T^2 Chart.
Mahal_UCL = function({p,m},
	sqrt(((m-1)^2)/m*beta quantile(0.95,p/2,(m-p-1)/2));
The formula is also given in the Multivariate Methods book on page 49 in the Help menu (Help > Books > Multivariate Methods).UCLFormula.PNG
Here's an example using the Thickness data.  The Mahalanobis control limit is 4.36.  Using the previously provided function, you can calculate the Mahalanobis distance UCL for m=50 data points and p=12 variables.  Here's the log output showing a matching control limit:
Mahal_UCL(12,50);
4.36283881449635
The function Mahal_UCL I wrote hard-codes in alpha = 0.05.  You could make alpha a 3rd parameter like so:
Mahal_UCL = function({p, m, alpha},
	sqrt( ( ( m-1 )^2 )/m*beta quantile( 1-alpha, p/2, ( m-p-1 )/2 ) );
-- Cameron Willden
AT
AT
Thanks so much for your help Cameron. This is very helpful.
cwillden
Hi @AT,
	Y(
		:Thickness 01,
		:Thickness 02,
		:Thickness 03,
		:Thickness 04,
		:Thickness 05,
		:Thickness 06,
		:Thickness 07,
		:Thickness 08,
		:Thickness 09,
		:Thickness 10,
		:Thickness 11,
		:Thickness 12
Mahal_UCL(12,50);
4.36283881449635
-- Cameron Willden
AT
AT
