miguello
How to get reference to a table within "On Close" in that table?
Hi!
I need some help with getting a reference to the table within On Close statement of that said table.
I have a simple script: GUI with "Open" button, that opens a data table, and a combo box with list of tables.
I also keep track of the tables in an associative array with table names as keys and table references as values.
I have a couple of legacy namespaces that I have to maintain in this script. In order to remove table from the the combo box I use this Eval(Eval Expr(Expr())) trick in OnClose statement. However, this trick doesn't work with removing table from Associative Array.
There is another trick with Function({this}, _dt = ((this << Child) << Get Data Table)). It works correctly with getting the reference to data table, but stops working when I place it within Eval(Eval Expr(Expr()))).
I tried to get the reference to the table separately, but looks like I don't know how Function({this}, <script>) works. How do I assign a result of this function to a variable?
Anyways, here's the latest iteration of my script, please help me tweak it to make it work.
Eventually, I will need to handle data table manual name changes somehow and reflect it in the combo box.
data = New Namespace(
	"DataTables"
gui = New Namespace(
	"GUI"
data:tablesListAA = [=> ];
gui:guiWindow = Expr(
	Border Box( Left( 10 ), Right( 10 ), Top( 10 ), Bottom( 10 ), Sides( 15 ),
		V List Box(
			gui:cb = Combo Box(
				selection = gui:cb << GetSelected();
				Print( "Selected: " || selection );
				Current Data Table( data:tablesListAA[selection] );
				Print( "Current Data Table: " || (Current Data Table() << Get Name) );
			Button Box( "Add Table",
				filePath = Pick File(
					"Select JMP File",
					"$SAMPLE_DATA",
					{"JMP Files|jmp;jsl;jrn", "All Files|*"},
					1,
					0,
					"newJmpFile.jmp"
				dt = Open( filePath );
				Eval(
					Eval Expr(
						dt << On Close(
							getTable = Function( {this},
										_table = ((this << Child) << Get Data Table);
										Return(_table);
							_table = getTable(this);
							Local( {data = Namespace( Expr( data << Get Name ) ), gui = Namespace( Expr( gui << Get Name ) ), _table = Expr(_table)},
								Try(
										_tableName = _table << Get Name;
										Print("Trying to remove: "||_tableName);
										Remove From( data:tablesListAA, _tableName );
										gui:cb << Set Items( data:tablesListAA << Get Keys );
				dtName = dt << Get Name();
				Insert Into( data:tablesListAA, dtName, dt );
nw = New Window( "Test table selection", gui:guiWindow );
Re: How to get reference to a table within "On Close" in that table?
Usually I just evaluate the table name/reference to the On Close. You can also use <<On Close(Function({this})) and this will be reference to the data table window (script index has example of this).
View more...
	"DataTables"
	"GUI"
	Border Box(Left(10), Right(10), Top(10), Bottom(10), Sides(15),
		V List Box(
			gui:cb = Combo Box(
				Print("Selected: " || selection);
				Current Data Table(data:tablesListAA[selection]);
				Print("Current Data Table: " || (Current Data Table() << Get Name));
			Button Box("Add Table",
				filePath = Pick File("Select JMP File", "$SAMPLE_DATA", {"JMP Files|jmp;jsl;jrn", "All Files|*"}, 1, 0, "newJmpFile.jmp");
				dt = Open(filePath);
				Eval(
					Eval Expr(
						dt << On Close(
							tb = Expr(dt);
							_tableName = tb << get name;
							Print("Trying to remove: " || _tableName);
				Insert Into(data:tablesListAA, dtName, dt);
				gui:cb << Set Items(data:tablesListAA << Get Keys);
nw = New Window("Test table selection", gui:guiWindow);
You might also consider using Subscribe To Data Table List() to keep track of the tables. I have used that to build something very similar to the table list you see for example on top of JMP's script editor and it is able to handle namechanges/table closures/opens (it is more complicated to build and does have its issues).
miguello
For some reason I decided that baking in table into Eval(Eval Expr(Excpr))) was wrong for this use case. LEt me try to re-write it again.
