Ake
Ake
How to get nonlinear fit parameters back to data table
I have used the nonlinear platform interactively to fit and estimate the parameters Max and k in a formula column as below. I would like to get the estimates back to the data table to use in other formula columns. I have searched, but not been able to figure out how to access them outside the column where the formula resides. I tried Save estimates to table, which gets them into a new separate table. Using jmp 16.0
peng_liu
Re: How to get nonlinear fit parameters back to data table
//add steps here to get Nonlinear Estimates table from Nonlinear platform.
name =  data table("nonlinear estimates"):parameter << get values;
value = data table("nonlinear estimates"):estimate << get values;
for (i=1,i<=length(name),i++,
	data table("original table") << Set Table Variable( name[i], value[i] )
Maybe try "Set Table Variable". Seems it is the same as "add" if the variable does not exist. I was thinking of "delete" before "add", but that may break dependencies if you build other things that depend on the variables.
Ake
Ake
This also worked perfectly! I might come back to expand the script to do the parts I did manually! :)
peng_liu
Here is an example to add them as table variables.
	data table("original table") << New Table Variable( name[i], value[i] )
Ake
Ake
Thank you so much for the super fast response! This works! Could you also suggest how to load the parameter values into already existing table variables (Max and k in this case), so I don't get new ones every time?
Best, Åke
peng_liu
Ake
Ake
