lala
Level IX
How to get non-duplicate column names from the "leaf label formula" of decision tree model?
For example, use the following JSL to get the Leaf Label Formula.Extract the column names from the formula in the first 10 rows.
d0 = Open( "$SAMPLE_DATA/Equity.jmp" );
p=Partition(
	Y( :BAD ),
	X(
		:LOAN, :MORTDUE, :VALUE, :REASON, :JOB, :YOJ, :DEROG, :DELINQ, :CLAGE, :NINQ,
		:CLNO, :DEBTINC
	Validation Portion( 0.3 )
p<<go;Wait(2);
p << save leaf label formula;
lala
Level IX
回复: How can duplicate column names not be extracted from the "Leaf Label Formula" of the decision tree model?
lala
Level IX
Current Data Table( d0 );
txt = "";
For( i = 1, i <= 10, i++,
	If( i == 1,
		a = "",
		a = "aaa"
	nn = d0[i, "Leaf Label Formula"];
	txt = txt || a || nn;
tx = "ccc\!n" || Substitute( txt, "&", "\!n", "aaa", "\!n", " or Missing", "", " not Missing", "", " Is Missing", "" );
tx = Substitute( tx, ">", "\!t>", "<", "\!t<", "(", "\!t(" );
d1 = Open( Char To Blob( tx ), "text" );
d2 = d1 << Summary( Group( ccc ), Freq( 0 ), Weight( 0 ), Link to original data table( 0 ) );
Re: How to get non-duplicate column names from the "leaf label formula" of decision tree model?
You could loop over all the possible column names and if match is found, add it to associative array (and remove from the column listing if you want to)
input_cols = {"LOAN", "MORTDUE", "VALUE", "REASON", "JOB", "YOJ", "DEROG", "DELINQ", "CLAGE", "NINQ", "CLNO", "DEBTINC"};
dt = Open("$SAMPLE_DATA/Equity.jmp");
part = dt << Partition(
	Y(:BAD),
	X(Eval(input_cols)),
	Validation Portion(0.3)
part << go;
part << save leaf label formula;
part << close window;
aa_cols = Associative Array();
For Each({row_val}, dt[1::10, "Leaf Label Formula"],
	input_cols_temp = input_cols;
	For Each({input_col, idx}, input_cols,
		If(Contains(row_val, input_col),
			aa_cols[input_col] = 1;
			Remove From(input_cols_temp, idx);
	input_cols = input_cols_temp;
