I d like to create a formula column (sum or mean etc.) with sub groups. The sub groups should be selected by rows, for example all 5 following rows drom a data table or in general all N rows. Any ideas to solve this with row()?
As I understand it, Local() simply let variables to be defined and evaluated within the context of the column formula, eliminating risk of interference with global variables with the same name. Parameters are used in optimization problems, i.e. the nonlinear platform.
