aaronjiang
How to generate multiple plots
I wrote a JMP script where I plot data based on my original data. After I manipulate data, I plot it again, but now it can only show the plot for data after manipulation, not the plot for original data. I would like to compare two. Could anyone help with this? Below is the script I used to plot the data.
Graph Builder(
	Size( 748, 531 ),
	Automatic Recalc( 0 ),
	Variables( X( :X_NOM_BIN ), Y( :Y_NOM_BIN ), Color( :Name( "Mean(UPDATED THICKNESS" ) ) ),
	Elements( Points( X, Y, Legend( 6 ) ) )
10 REPLIES 10
aaronjiang
Re: How to generate multiple plots
And i want to have separate plots. One plot for table dt, another plot for table dtNew. Basically showing two plots on separate graphs.
