aaronjiang
How to generate multiple plots
I wrote a JMP script where I plot data based on my original data. After I manipulate data, I plot it again, but now it can only show the plot for data after manipulation, not the plot for original data. I would like to compare two. Could anyone help with this? Below is the script I used to plot the data.
Graph Builder(
	Size( 748, 531 ),
	Show Control Panel( 0 ),
	Automatic Recalc( 0 ),
	Variables( X( :X_NOM_BIN ), Y( :Y_NOM_BIN ), Color( :Name( "Mean(UPDATED THICKNESS" ) ) ),
	Elements( Points( X, Y, Legend( 6 ) ) )
10 REPLIES 10
Re: How to generate multiple plots
I am not sure if you manipulate the data in the X role, the Y role, or both roles. You could save the manipulated data in a new column. You could also stack the original and manipulated data into one column and automatically create a label column to indicate which data is before and which data is after the manipulation.
aaronjiang
Here is a more detailed description of my problem
For example, if I have a data table below (dt):
A B
1 2
2 4
3 6
4 8
And I manipulate data to make another table (dtNew)
A B
1 4
2 8
3 10
4 12
Now I want to plot this two on separate plots. How can I do that?
I see. Select Tables > Join. Change the Match option to Row Number. Now you have both data sets in the same table.
aaronjiang
Thanks. But how to use JMP script to address this? I am creating a script that can do everything by just one click
Here is a very simple example on one way to do this:
dt << select where( :SEX == "F" );
dt2 = dt << subset( selected rows( 1 ), selected columns( 0 ) );
dt << bivariate( x( :Height ), y( :weight ) );
dt2 << bivariate( x( :Height ), y( :weight ) );
or
data table("big class") << select where( :SEX == "F" );
data table("big class") << subset( selected rows( 1 ), selected columns( 0 ) );
data table("big class") << bivariate( x( :Height ), y( :weight ) );
data table("Subset of big class") << bivariate( x( :Height ), y( :weight ) );
aaronjiang
Thanks. What if I have a third dimension to plot a heat map plot. What function should be used in plotting (rather than bivariate)?
You can use Graph Builder to generate a Heat Map, or you can use a Cell Map.
You should take a look at the documentation
     Help==>Books==>Essential Graphing
aaronjiang
Here is what I have. It always generate the second plot, but not the first. Could you tell me why?
dtSum << Graph Builder(
	Size( 748, 531 ),
	Variables( X( :X_NOM_BIN ), Y( :Y_NOM_BIN ), Color( :UPDATED THICKNESS 1 ) ),
dtSum6 << Graph Builder(
	Size( 748, 531 ),
	Variables( X( :X_NOM_BIN ), Y( :Y_NOM_BIN ), Color( :Name( "RESIDUAL1_Normalized" ) ) ),
What are the messages in the log?
What is the value of the variable DTSUM?  If you put
     show(DTSUM);
just before
it will print to the log what the value is......it needs to have the value of
     dtSum = Data Table( "your data table name" )
