mwei04
How to generate bar graphs that show significance between bars?
I would like to generate graphs that show significance between levels like this: Screen Shot 2017-05-17 at 1.28.02 PM.png
My current graphs contain everything shown above except the lines and stars showing significance. I saw a previous post which shows how to label each bar with a star to indicate significance against a control, but is there a way to indicate significance against each category in JMP?
Re: How to generate bar graphs that show significance between bars?
The simplest way to do this in JMP is to use the Fit Y by X platform, and select  one of the means comparisons to get the Comparison Circles for one or more of the statistics.
You can get the details on this technique by running a sample analysis, and then either selecting the ? tool, or typing in "?" and then clicking on the comjpairson circles
