Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
JK
JK
How to fix the y-axis range in distribution graph?
I generated 20 different distribution graphs and it has different y-axis range. I want to fix the y-axis range (0 to 80) at one time. Now I'm changing the range (0 to 80) in every graph one by one and it takes lots of time. Could you guide me how to change the range in the more easy way?
Many thanks in advance!!!
Jin.W.Kim
Re: How to fix the y-axis range in distribution graph?
Set the axis on one of the graphs to the settings you want. Then right click on the axis and select
Edit==>Copy Axis Settings
Then hold down the CNTL key and select
Edit==>Paste Axis Settings
and the axis settings will be copied to all of your histograms in the Distribution window. Holding down the CNTL key while performing selections in JMP is a universal action, to replicate the action across all similar objects in the window you are working in. (i.e. Resizing graphs, selecting red triangle options, etc.)
Try the Uniform Scaling command in the top most context menu (red triangle).
JK
JK
Thank you for your message!! The Uniform Scaling is so helpful!!! But I can't decide the specific range which I want to fix, right? I found the solution using 'Copy Axis Settings', Thanks a lot!!!
Jin.W.Kim
JK
JK
Wow~ Many thanks!!! I solved it:) Thank you for so clear solution!!!
Jin.W.Kim
Also, you can 'broadcast' many commands and actions by holding the Control key on Windows or Command key on Mac. For example, if hold this key and resize one plot by dragging, all such plots will adopt the new size when you release the mouse button.
