  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
How to find relation in parameters pairs in one variable
Hi
I have a table with a failure list.
Each row has a systems ID and parts failed number
 I would like to test if there are pairs of parts (or pairs). This means if there are pairs of parts in a system that fails together.
If the parts fail together it will be shown by two different rows.
Re: how to finde relation in parameters pairs in one vaerible
It is not clear exactly what you want, but try this: select Table > Summary. Select system ID and click Group. Click OK. You should get a summary table that is linked to the original table. A new column indicates how many rows in the original table are included in each row of the summary. Any summary row for system ID with N Rows > 1 has more than one part failure.
Hi, thanks
I tried to explain it better in the second post
https://community.jmp.com/t5/Discussions/How-to-analyze-pairs-of-parameters-in-one-variou/m-p/470558...
but didn’t know how to delete this one
thanks again for your reply
