qunw
How to filter a group of columns by a defined list of selection
Hi JMP community,
I'd like to filter a group of columns in a table based on the "Response Screening" results, which provided a list of statistically significant markers of interest with p and FDR values, e.g., the top 20 significant markers.  And the "Response Screening" result was embedded and saved in the data table.  How can I filter the 20 columns in the data table, where the column names match the marker names in the list of selection (one marker, one column)?  Many thanks!
Re: How to filter a group of columns by a defined list of selection
Hi @qunw ,
You have to do the 'Select Where' first, press 'OK', then click the 'Select Columns' to have it reflected in the data table.
Thanks,
Ben
Hi @qunw ,
You can use the 'Select Columns' option in the report for Response Screening:
Thanks,
Ben
qunw
Hi Ben,
Thanks so much for your prompt help!  I tried, but it didn't work out for me.
I filtered the Response Screening table by the FDR logworth > 14, and none of the columns were selected in the original table. Did I do anything not correctly?
Many thanks!
Hi @qunw ,
Thanks,
Ben
qunw
Yes, Ben, it works nicely!  Thank you so much for your help on this query!
