chandankishor66
How to fill missing dates within column
Hi JMP users,
I have a table which contains two columns.
1. Time
2. Date.
Time column has continuous entries but Date column has only few entries and that entries denote samples loading time/date.
How to completly fill the date coulm for each day. Screnshoot attached below
Regards,
Re: How to fill missing dates within column
Interactively, you can right click on a filled date cell and select "fill", and then you can choose to fill to the end of the table, or fill to a specified row.
Or you can run this little script and it will do the job for you
For Each Row(
	If( Is Missing( :date ) == 0,
		currDate = :date
	:date = currDate;
For Each Row(
		currDate = :date
	:date = currDate;
