Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
RobRobeyns
How to extract a report name in a generic way using jsl
I would like to extract the report name using jsl. The script posted below is able to do so, but not for all types of reports. For example: I am able to extract the correct report name for a Graphbuilder report, but not for a Fit Manova report.
This results in an error: "Name Unresolved: rescript in access or evaluation of 'repscript', repscript/*###*/"
Is there a solution to make this script more generic/robust, so that it would work for all types of reports?
dt=Current Data Table();
rep=Current Report();
//data table name
dtname=dt<<Get Name();
//Report title, Scriptable Object, and finally script of report in Char form
reptitle=rep<<get window title;
substitute into(reptitle,Eval(dtname)||" - ","");
//capture first word of reptitle
reptitlefw= word(1,reptitle," ");
report_type=reptitlefw||" ?";
//Eval(Parse(Eval Insert("repSO=rep[^(report_type)^]<<get scriptable object;")));
Try(Eval(Eval Expr(repSO=rep[Expr(report_type)]<<Get Scriptable Object));
repscript=Char(repSO<<get script));
//get array of row states
rowstates=dt<<get row states;
//script that sets row states to values in array
rowstatescript=Eval Insert(
"Names Default To Here(1);
rowstates=^Char(rowstates)^;
for(i=1,i<=NRows(dt),i++,
Row State(dt,i)=As Row State(rowstates[i]);
//save script for row states and report to data table
eval(parse("dt<<new script(reptitle,"||rowstatescript||repscript||")"));
Re: How to extract a report name in a generic way using jsl
The issue with the JSL you have been using, is that not all window titles provide the correct information to get the Scriptable Object that can retrieve the Script.  I have found that using the initial Outline Box() from within the window is a more robust method.  However, it still will not work in all cases.  If a BY() group is specified, it will return the script for only the first BY() group.  Here is my modification to the code
//data table name
// The Get Scriptable Object is a message available to the Report's
// initial Outline Box
repSO = window(reptitle)[outlinebox(1)]<<get Scriptable Object;
repscript=Char(repSO<<get script);
I modified your script a bit so that it now gets the scriptable object from OutlineBox(1) of the current report, rather than trying to use the report name (see below).  Please try it out and let me know if it works for you.
repSo=rep[OutlineBox(1)]<<Get Scriptable Object;
//data table name
//data table name
RobRobeyns
Thanks for the solution Jim and Hadley!
Much appreciated!
