poulravn
How to extend the IF command in a formula? Equivalent of select;when;when;otherwise;end;
Hi, I want to be able, in a scripted formula, to assign a text string to column depending onthe values of another column.
For instance:
A  B
1  Low
2  Low
3  Low
4  Medium
5  Medium
6  Medium
7  High
8  High
9  High
10 High
How does the formula lok for this?  If(:A<=3,"Low",:A>=3 and :A<7,"Medium",:A>=7,"High") does not work.
I Base SAS there is a command, select(); when();when(); ; ; otherwise;end; It is the equivalent of this I am looking for.
Regards
Poul Ravn Sørensen
Jeff_Perkinson
Re: How to extend the IF command in a formula? Equivalent of select;when;when;otherwise;end;
Hi Poul,
You've got the right idea, just the wrong logical operator.
In JSL the AND operator is &. So, your formula should be:
     If(:A <= 3, "Low",
        :A >= 3 & :A < 7, "Medium",
        :A >= 7, "High")
-Jeff
-Jeff
You could use a format:
DATA HAVE;
DO A = 1 TO 10;
OUTPUT;
END;
RUN;
PROC FORMAT ;
VALUE RATING
LOW - 3  = "LOW"
4-6  = "MEDIUM"
7 - HIGH = "HIGH";
RUN;
DATA WANT;
  SET HAVE;
  B = PUT(A,RATING.);
RUN;
Or Using:
DATA WANT;
    ATTRIB C LENGTH = $6;
  SET HAVE;
/* B = PUT(A,RATING.);*/
      IF A <= 3 THEN C = "LOW";
  ELSE IF 4 <= A <= 6 THEN C = "MEDIUM";
  ELSE C = "HIGH";
RUN;
poulravn
I am sorry. This is the SAS program version, but I was trying to find the JMP Script formula for the same. Should have been more precise. Exactly this example shows how you would sometimes prefer to have a more comprehensive Scripting Guide. I found nothing to help me in the guide.
Regards
Poul
djchavda
Try this
if A <= 3 then B="Low";
else if A > 3 and A <= 6 then B="Medium";
else B="High";
poulravn
Again I am sorry; this works fine in SAS but I am looking for the JMP Formula (based on IF, MATCH or CHOOSE?) that does the same.
Regards
Poul
Jeff_Perkinson
Hi Poul,
     If(:A <= 3, "Low",
        :A >= 7, "High")
-Jeff
-Jeff
Article Labels
