How to edit cause and effect diagram?
I am taking the Statistical Thinking course and part of the coursework is creating a cause and effect diagram. I am trying to edit within that tool in JMP 16 but cannot find any documentation on how to use it. Simple tasks like adding another "bone" are not something I can figure out how to do.
I am halfway competent in Visio so this kind of diagram isn't new to me. Just need to know how to do it.
Can someone point me in the right direction?
Re: How to edit cause and effect diagram?
Basically, to edit the Ishikawa diagram, you hover over the area you want to change, an outline box normally appears and then you right click to get a list of actions
Chapter 14 in the Quality and Process Methods document in the JMP Documentation Library, details the platform.
Also, If you select the "?" tool from the tool bar, and then click on the diagram, the JMP Help system will bring up documentation on how to use the platform.
