Pushpendra
How to edit X-axis Group name in variability chart using script
Hello All,
I have plotted a variability chart by grouping some variable using script.
Please find the attached plot.
I don't want to print group variable name into the x-axis but I want it in the variable title name.
Could you please give a solution to delete the X variable name from the X axis.
Thanks in advance.
Re: How to edit X-axis Group name in variability chart using script
Here are 3 ways to edit out the Group 1 X axis
// Setup some sample data to resemble the example provided
dt = Open( "$SAMPLE_DATA\Semiconductor Capability.jmp" );
dt:NPN1 << set name( "ISO_NW-N+" ) << set property( "Units", "A" );
dt << New Column( "Lot_Des", character, set each value( "ML7" ) );
dt << New Column( "DR", character, set each value( "S_0.40" ) );
dt << New Column( "Group 1", character, set each value( "ISO_NW-N+" ) );
// Sample 1, use the window name as the reference to delete the
// 2 components of the X axis that are not wanted
Variability Chart(
	Y( :Name( "ISO_NW-N+" ) ),
	X( :Group 1, :DR, :Lot_Des, :wafer ),
	Max Iter( 100 ),
	Conv Limit( 0.00000001 ),
	Number Integration Abscissas( 128 ),
	Number Function Evals( 65536 ),
	Analysis Type( "Choose best analysis (EMS REML Bayesian)" ),
	Std Dev Chart( 0 )
Window( "Semiconductor Capability - Variability Chart of ISO_NW-N+" )[Border Box( 5 )] << delete;
Window( "Semiconductor Capability - Variability Chart of ISO_NW-N+" )[NomAxisBox( 4 )] << delete;
// Sample 2, Set a Pointer/Handle variable reference to delete the
VC = Variability Chart(
	Max Iter( 100 ),
	Std Dev Chart( 0 )
Report( VC )[Border Box( 5 )] << delete;
Report( VC )[NomAxisBox( 4 )] << delete;
// Sample 3, Since there is only 1 value for the Group 1 column,
// and the title of the chart will come from the Y Column, not
// the X Column, then just leave Group 1 out of the definition
// of the chart
Variability Chart(
	X( :DR, :Lot_Des, :wafer ),
	Max Iter( 100 ),
	Std Dev Chart( 0 )
Variability Chart(
	Max Iter( 100 ),
	Std Dev Chart( 0 )
	Max Iter( 100 ),
	Std Dev Chart( 0 )
// of the chart
Variability Chart(
	Max Iter( 100 ),
	Std Dev Chart( 0 )
Pushpendra
Thank you so much.
It is working fine.
