miguello
How to dynamically create and address namespaces? Independent handles on multiple GB plots.
All,
I can't wrap my head around this problem:
I need to put handles on my GB plots. I have multiple GB plots in one window. The variables in the handles script cross-talk. I need to either use new variables in each script, or create a new namespace for each graphics script (seems the way to go for me). But then again - as soon as I create a namespace, I address it through a reference variable - which gets overwritten each time I create a new namespace.
In the example below I just use different variable names, but it needs to be  created dynamically and addressed properly.
I remember there was some trick using something like:
ns = Namespace( Expr( ns << Get Name ) )
but I'm not sure if it is applicable in this case and to be frankly I'm not sure I understand how and why it's working where I'm currently using it.
Here's an example script:
lub = Lineup Box( N Col( 2 ) );
ns1 = New Namespace(
	"height"
ns1:_x_location_ = 2;
ns1:_y_location_ = 50;
lub << Append(Graph Builder(
	Size( 528, 450 ),
	Show Control Panel( 0 ),
	Variables( X( :age ), Y( :height ), Overlay( :sex ) ),
	Elements( Points( X, Y, Legend( 6 ) ) ),
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Add Graphics Script(
				2,
				Description( "" ),
				Handle(
					ns1:_x_location_,
					ns1:_y_location_,
					ns1:_x_location_ = x;
					ns1:_y_location_ = y;
ns2 = New Namespace(
	"weight"
ns2:_x_location_ = 2;
ns2:_y_location_ = 50;
	Size( 528, 450 ),
	Variables( X( :age ), Y( :weight ), Overlay( :sex ) ),
		Dispatch(
			"Graph Builder",
			FrameBox,
				2,
				Description( "" ),
				Handle(
					ns2:_x_location_,
					ns2:_y_location_,
					ns2:_x_location_ = x;
					ns2:_y_location_ = y;
win = New Window( "Independent Handles Example",lub);
Re: How to dynamically create and address namespaces? Independent handles on multiple GB plots.
I think you could just skip namespaces (in this case) and utilize Context Box
lub = Lineup Box(N Col(2));
lub << Append(
	cb1 = Context Box(
		box:_x_location_ = 2;
		box:_y_location_ = 50;,
		Graph Builder(
			Size(528, 450),
			Show Control Panel(0),
			Variables(X(:age), Y(:height), Overlay(:sex)),
			Elements(Points(X, Y, Legend(6))),
				Dispatch({}, "Graph Builder", FrameBox,
						2,
						Description(""),
						Handle(
							box:_x_location_,
							box:_y_location_,
							box:_x_location_ = x;
							box:_y_location_ = y;
lub << Append(
	cb2 = Context Box(
		Graph Builder(
			Size(528, 450),
			Variables(X(:age), Y(:weight), Overlay(:sex)),
						2,
						Description(""),
						Handle(
							box:_x_location_,
							box:_y_location_,
win = New Window("Independent Handles Example", lub);
lub << Append(
	cb1 = Context Box(
		Graph Builder(
			Size(528, 450),
						2,
						Description(""),
						Handle(
							box:_x_location_,
							box:_y_location_,
lub << Append(
	cb2 = Context Box(
		Graph Builder(
			Size(528, 450),
						2,
						Description(""),
						Handle(
							box:_x_location_,
							box:_y_location_,
miguello
So if I'm dynamically creating these GBs and adding them to my Line Up Box, this Context Box should isolate variables inside itself just like {Default Local} does that inside a function? Let me try that.
miguello
Nope, doesn't work. Handles do not behave independently. I move the handle on Plot 1, as soon as I click on Plot 2 handle there jumps to the location where the handle is on Plot 1.
Here's the script:
lub << Append(
	Context Box(
		_x_location_ = 2;
		_y_location_ = 50;
		Graph Builder(
			Size( 528, 450 ),
				Dispatch(
					"Graph Builder",
					FrameBox,
						2,
						Description( "" ),
						Handle(
							_x_location_,
							_y_location_,
							_x_location_ = x;
							_y_location_ = y;
lub << Append(
	Context Box(
		_x_location_ = 2;
		_y_location_ = 50;
		Graph Builder(
			Size( 528, 450 ),
				Dispatch(
					"Graph Builder",
					FrameBox,
						2,
						Description( "" ),
						Handle(
							_x_location_,
							_y_location_,
							_x_location_ = x;
							_y_location_ = y;
win = New Window( "Independent Handles Example", lub );
Compare our scripts and you will most definitely notice a difference (just having Context Box isn't enough, you also have to utilize it).
miguello
Oops, sorry... :) My bad :)
When correctly written, it DOES work. Thanks a lot!
