lala
Level IX
How to dynamically change the vertical line of the X-axis?
I draw the graph like this, and then loop it once every minute. The requirement is that the vertical line of the X-axis can be changed according to the value of the specified variable
Thanks Experts!
a=26;
dt=Open("$SAMPLE_DATA/Big Class.jmp");
ca="r";New Column(ca);
p1=dt<< Graph Builder(
	Variables( X( Transform Column( "Row", Formula( Row() ) ) ), Y( :height ) ),
	Elements( Line( X, Y, Legend( 5 ) ) ),
		Dispatch(
			"Row",
			ScaleBox,
			{Add Ref Line( a, "Dotted", "Medium Light Red", "", 1 )}
While( 1,
a=Random Integer(1, 40);//Column(ca)<<Formula( if(row()==a,row()) );dt<<run formulas;Column(ca)<<deleteFormula;
Wait( 60 );
Re: How to dynamically change the vertical line of the X-axis?
You might have to add it to all of the frameboxes (Wrap / X Group / Y Group do create multiple)
a = 26;
gb = dt << Graph Builder(
	Transform Column("Row", Formula(Row())),
	Size(525, 496),
	Show Control Panel(0),
	Variables(X(:Row), Y(:height), Wrap(:age)),
	Elements(Line(X, Y, Legend(5)))
fbs = Report(gb) << XPath("//FrameBox");
fbs << Add Graphics Script(
	Pen Size(2);
	V Line(a);
For(i = 1, i <= 10, i++,
	a = Random Integer(1, 40); // could also use table variable
	Wait(0.5);
	Report(gb) << Inval;
	Report(gb) << Update Window;
Write();
6 REPLIES 6
lala
Level IX
回复: How to dynamically change the vertical line of the X-axis?
OK
gb_report = p1 << Report;
axisbox = gb_report[Axis Box( 1 )];
While( 1,
	axisbox << Remove Ref Line( a );
	a = Random Integer( 1, 40 );
	axisbox << Add Ref Line( a, "Dotted", "Medium Light Red", "", 1 );
	Wait( 2 );
lala
Level IX
It seems that encountering an overlap like wrap is not that simple
Use Graphic Script with "global" variable
a = 26;
	Variables(X(Transform Column("Row", Formula(Row()))), Y(:height)),
Report(gb)[FrameBox(1)] << Add Graphics Script(
	Pen Size(2);
	V Line(a);
	Wait(0.5);
Write();
lala
Level IX
When it comes to practical examples, I still don't know.
The graph overlapped with wrap
The other effects originally set have disappeared and no vertical lines have appeared either.
lala
Level IX
a = 26;
	Size(525, 496),
	Pen Size(2);
	V Line(a);
	Wait(0.5);
Write();
