Jackie_
Add text annotation on the Graph Builder
Is there a way to write a graphics script to add text annotation to each reticles on the wafer map?
Additionally, I want to color two columns - 'Ret' and '%Fail', create a heat map with %Fail col and overlay Ret col. Is this possible on GB?
TIA
Re: Add text annotation on the Graph Builder
/*""" Reticle outline and names
Author: jthi
Creation Date: 2025-06-25
Creation JMP Version: JMP Pro 18.2.0
dt = Open("$DOWNLOADS/dataTable.jmp");
Summarize(dt, rets = By(:Ret));
aa = Associative Array();
For Each({curret}, rets,
	r = dt << Get Rows Where(:Ret == curret);
	tri = Triangulation(X(dt[r, "X"], dt[r, "Y"]));
	path = tri << Get Hull Path;
	aa[curret] = Associative Array();
	aa[curret]["Path"] = path;
	aa[curret]["X"] = Median(dt[r, "X"]);
	aa[curret]["Y"] = Median(dt[r, "Y"]);
gb = dt << Graph Builder(
	Size(937, 542),
	Show Control Panel(0),
	Variables(X(:X), Y(:Y), Color(:"%Fail"n)),
	Elements(Points(X, Y, Legend(10)))
For Each({{retname, param}}, aa,
	Eval(EvalExpr(
		Report(gb)[FrameBox(1)] << Add Graphics Script(
			Pen Color("Red"); // outline color for reticles
			Pen Size(3); // reticle outline size
			Path(Expr(param["Path"]), 0); // plots reticle outline
			Text Color("Black"); // text color
			Text Size(10); // text size for reticle
			Pen Color("Black"); // text box outline color
			Pen Size(2); // outline size for text box
			Text(Boxed, Erased, Center Justified, {Expr(param["X"]), Expr(param["Y"])}, Expr(retname));
You could potentially move the loop inside graphic script and not create looped scripts (I haven't tested which would be better).
Edit: Added image of the final solution
How would you color with two columns in this case? Reticle would define the main color and %Fail the gradient or something similar? Have you considered creating shape map file for this type of analysis?
You can use graphic script to add the text annotation
dt = Current Data Table();
	Size(979, 588),
	Variables(X(:X), Y(:Y), Overlay(:Ret)),
	Elements(Points(X, Y, Legend(10)), Smoother(X, Y, Legend(11)))
Summarize(dt, rets = By(:Ret), mx = Mean(:X), my = Mean(Y));
// Lazy option without evaluation
	For(i = 1, i <= N Items(rets), i++,
		Text Size(12);
		Pen Color("Black");
		Pen Size(3);
		Text(Boxed, Erased, Center Justified, {mx[i], my[i]}, rets[i]);
Jackie_
Hi @jthi ,
I have tried the shap map, but it slows down JMP because I have 1 million rows.
I was thinking if there's a way to draw the border around the reticles using graphic script, I can border those reti on wafer map and this will let me distinguish the reticles, and then I can add %Fail to the color selection on the legend
Thanks,
You can do something like this
or maybe with a heatmap
Jackie_
@jthi This looks great. Can you share the code?
Author: jthi
	Size(937, 542),
	Eval(EvalExpr(
