How to determine min and max of axis using JSL?
Hi
Does anyone know how to determine the min and max values for an axisbox? There are Min ans Max messages but these only allow you to set the values - I need to read them.
Thanks
Re: How to determine min and max of axis using JSL?
I don't know if there's an easier way of doing it than this, but the following seems to do the trick by assigning all the properties of axis box[1] and axis box[2] to the appropriate columns of Big Class, from where they can presumably be extracted:
open("$SAMPLE_DATA/Big Class.jmp");
gg = Overlay Plot( X( :height ), Y( :weight ), Separate Axes( 1 ) );
ggr = gg << report;
show properties(ggr[axis box(1)]); // to see what the options are;
ggr[axis box(1)] << save to column property;
ggr[axis box(2)] << save to column property;
Does that solve the problem?
mpb
mpb
Building on this try the following:
style="color: rgb(0, 0, 221);">Open
"$SAMPLE_DATA/Big
Class.jmp"
style="color: navy;">;
gg
Overlay Plot(
X(
:height
style="color: navy;">,
Y(
:weight
Separate Axes(
style="color: teal;">1
ggr =
gg <<
report
style="color: rgb(0, 0, 221);">Show Properties
ggr[axis
box(
to see what the
options are;
axinfo1
ggr[axis
box(
copy axis settings
style="color: navy;"><<
get script;
axinfo2 =
ggr[axis
box(
style="color: teal;">2
copy axis settings
get script;
axinfo1,
axinfo2 )
Max1
axinfo1[
style="color: purple;">"Max"
Min1 =
axinfo1[
style="color: purple;">"Min"
Max2 =
axinfo2[
Min2 =
axinfo2[
Max1,
Min1,
Max2,
Min2 )
Two great tips.
These should solve the immediate problem and I suspect a number of others where we have to go through slight convolutions to get JSL to do the things we "think" it should be able to do.
Many thanks
wiebepo
This worked for me in JMP 10.0.0
Building off of DavidQR's example:
axis_setting_Min=(report(gg)[axisbox(1)]<<getscript())["Min"];
axis_setting_Max=(report(gg)[axisbox(1)]<<getscript())["Max"];
