KarlK
How to delete numbers in brackets from letter- sequences
How can I find modified peptide sequences (e.g., SYELPDGQV(+.98)I(+10.98)T(-17.03)IGNER ) in the Jump table when searching the unmodified sequence (SYELPDGQVITIGNER)?
If the search algorithm cannot be modified, is it possible to generate a new column by deleting all number in brackets from the all-letter- sequences?
e.g., entry original column: NLTEE(+.98)LAGLDE(+28.99)T(+10.98)IAK
automatically generating new column with entry: NLTEEMAGLDETIAK
Re: How to delete numbers in brackets from letter- sequences
You could create new column using Regex or Substitute
str1 = "NLTEE(+.98)LAGLDE(+28.99)T(+10.98)IAK";
str2 = "SYELPDGQV(+.98)I(+10.98)T(-17.03)IGNER";
Show(Regex(str1, "[^ABCDEFGHIJKLMNOPQRSTUVWXYZ]", "", GLOBALREPLACE));
Show(Regex(str2, "[^ABCDEFGHIJKLMNOPQRSTUVWXYZ]", "", GLOBALREPLACE));
This assumes that you want to only keep the letters. You can build it for example by using Recode
and you can use regular expressions with search also
Edit:
Better regex is most likely something like this
res1 = Regex(str1, "\(.*?\)", "", GLOBALREPLACE);
res2 = Regex(str2, "\(.*?\)", "", GLOBALREPLACE);
show(res1, res2);
Edit:
show(res1, res2);
You can also use Substitute
res1 = Substitute(str1, Items(Get Punctuation Characters(Include Chars("0123456789")), ""), "");
res2 = Substitute(str2, Items(Get Punctuation Characters(Include Chars("0123456789")), ""), "");
or build regex using JMP's text explorer
Do note that this will leave them as separate "words" as it is used for Text Explorer, so you have to remove the spaces, this can be done with Search for example
KarlK
Thank you very much for your quick and helpful answers
