Dennisbur
How to delete hidden and excluded rows by JSL
Hello
I have a table, and some of the rows are hidden and excluded
I would like to delete them by JSL script
I tried this script, but nothing happened,
dt << Select Where (:Excluded == 1 | :Hidden == 1);
dt << Delete Rows ( );
Can you provide me a solution, please?
Re: How to delete hidden and excluded rows by JSL
Excluded and Hidden aren't columns  so you cannot refer to them with :Hidden and :Excluded. You can use functions though
dt = Current Data Table();
dt << Select Where(Hidden() | Excluded()) << Delete Rows;
Edit:
One thing to note here is that this is checking for either hidden OR excluded not for both. If you want to check for both, you should use and operator (&).
dt << Select Where(Hidden() & Excluded()) << Delete Rows;
Edit:
